Saltar al contenido principal
Inglés
Español
Paso 4
The battery on the Nano is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In this step, you will heat each solder pad individually while using a metal spudger to pry it up from the logic board.
  • The battery on the Nano is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In this step, you will heat each solder pad individually while using a metal spudger to pry it up from the logic board.
  • DO NOT bridge the connection between the solder pads both on the board and on the ribbon cable with your spudger. Shorts have the potential to ruin the logic board.
  • Beware of overheating the board and the cable. Only hold the tip of the iron against the pad long enough to let the solder melt. Excess heat buildup has the potential to ruin the logic board or melt the ribbon cable.
  • Start working from the right side of the battery ribbon cable. Heat the rightmost solder pad while gently prying up from under the ribbon cable to free it from the board.
La batería del Nano se conecta a través de almohadillas de soldadura con pequeños orificios que pasan a través del cable de cinta de la batería y se unen a las almohadillas planas en la parte frontal de la placa lógica. En
este paso, calentará cada almohadilla de soldadura individualmente mientras usa un spudger de metal para extraerlo de la placa lógica.
NO puentees la conexión entre las almohadillas de soldadura tanto en la placa como en el cable plano con su spudger ya que se puede arruinar la placa lógica.
Ten cuidado de no sobrecalentar la placa y el cable. Solo sostenga la punta de la plancha contra la almohadilla el tiempo suficiente para que la soldadura se derrita. El exceso de acumulación de calor puede arruinar la placa lógica o fundir el cable plano.
Comienza a trabajar desde el lado derecho del cable de cinta de la batería. Calienta la almohadilla de soldadura más a la derecha mientras levantas suavemente hacia abajo desde debajo del cable de cinta para liberarlo del tablero.
