Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 17 guías que incluyan este paso.
Inglés
Español
Paso 2
Slightly lift the antenna plate from the end closest to the RAM. Carefully pull the antenna plate straight away from the circular rim of the outer case.
  • Slightly lift the antenna plate from the end closest to the RAM.
  • Carefully pull the antenna plate straight away from the circular rim of the outer case.
  • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
Insertar traducción aquí
