Saltar al contenido principal
BlackBerry Z10 Screen Replacement
Inglés
Español
Paso 4
BlackBerry Z10 Screen Replacement: paso 0, imagen 1 de 3 BlackBerry Z10 Screen Replacement: paso 0, imagen 2 de 3 BlackBerry Z10 Screen Replacement: paso 0, imagen 3 de 3
  • The motherboard is fragile. Make sure all connectors have been detached before you remove the motherboard.
  • Carefully remove the motherboard and set it aside on an antistatic surface.
  • Depending on the part you bought, you may be able to skip the remaining steps. A complete screen and case assembly can be purchased together. If that's what you have, simply move the motherboard to the new piece and reverse the steps above to reassemble your device. Otherwise, continue with the steps below.
Insertar traducción aquí
