Saltar al contenido principal
BlackBerry Z10 Rear Facing Camera Replacement
Inglés
Holandés
Traduciendo paso 10
Paso 10
BlackBerry Z10 Rear Facing Camera Replacement: paso 0, imagen 1 de 3 BlackBerry Z10 Rear Facing Camera Replacement: paso 0, imagen 2 de 3 BlackBerry Z10 Rear Facing Camera Replacement: paso 0, imagen 3 de 3
  • Remember to use the nylon spudger.
  • To disconnect the rear camera from the motherboard, carefully lift up the gold-plated connector. It is located just below the rear camera.
  • Then, hold and remove the rear camera using your thumb and index finger. It should detach along with the connector. Finally, set the rear camera aside.
Insertar traducción aquí
