Saltar al contenido principal
Desmontaje del iPhone 6 Plus
Inglés
Español
Paso 21
iPhone 6 Plus Teardown: paso 0, imagen 1 de 1
  • Back of the logic board.
  • SK Hynix H2JTDG8UD1BMS 128 Gb (16 GB) NAND Flash
  • Murata 339S0228 Wi-Fi Module
  • Apple/Dialog 338S1251-AZ Power Management IC
  • Broadcom BCM5976 Touchscreen Controller
  • NXP LPC18B1UK ARM Cortex-M3 Microcontroller (also known as the M8 motion coprocessor)
  • NXP 65V10 NFC module + Secure Element (likely contains an NXP PN544 NFC controller inside)
  • Qualcomm WTR1625L RF Transceiver
Parte posterior de la placa lógica.
Flash SK Hynix H2JTDG8UD1BMS 128 Gb (16 GB) NAND
Módulo WiFi Murata 339S0228
Circuito integrado de manejo de energía Apple/Dialog 338S1251-AZ
Controlador de pantalla táctil Broadcom BCM5976
Microcontroladores NXP LPC18B1UK ARM Cortex-M3 (también conocidos como Coprocesadores de Movimiento M8)
Módulo NFC NXP 65V10 + elemento seguro (Es muy probable que contenga un controlador NXP PN544 NFC en el interior)
Chip transceptor Qualcomm WTR1625L RF
[* black] Back of the logic board.
[* red] SK Hynix [https://www.skhynix.com/inc/pdfDownload.jsp?path=/datasheet/Databook/Databook_2Q%272014_All.pdf|H2JTDG8UD1BMS|new_window=true] 128 Gb (16 GB) NAND Flash
- [* orange] Murata 339S0228 Wi-Fi Module
- [* yellow] Apple/Dialog 338S1251-AZ Power Management IC
+ [* orange] Murata [https://chipworks.secure.force.com/catalog/ProductDetails?sku=MUR-339S0228&viewState=DetailView&cartID=&g=|339S0228|new_window=true] Wi-Fi Module
+ [* yellow] Apple/Dialog [https://chipworks.secure.force.com/catalog/ProductDetails?sku=APP-338S1251-AZ&viewState=DetailView&cartID=&g=|338S1251-AZ|new_window=true] Power Management IC
[* green] Broadcom [link|https://chipworks.secure.force.com/catalog/ProductDetails?sku=BRO-BCM5976A0KUB2G|BCM5976|new_window=true] Touchscreen Controller
[* blue] NXP [http://www.nxp.com/documents/user_manual/UM10430.pdf|LPC18B1UK|new_window=true] ARM Cortex-M3 Microcontroller (also known as the M8 motion coprocessor)
- [* violet] NXP 65V10 NFC module + Secure Element (likely contains an NXP [http://www.nxp.com/documents/leaflet/75016890.pdf|PN544|new_window=true] NFC controller inside)
+ [* violet] NXP [https://chipworks.secure.force.com/catalog/ProductDetails?sku=NXP-65V10&viewState=DetailView&cartID=&g=|65V10|new_window=true] NFC module + Secure Element (likely contains an NXP [http://www.nxp.com/documents/leaflet/75016890.pdf|PN544|new_window=true] NFC controller inside)
[* black] Qualcomm [https://chipworks.secure.force.com/catalog/ProductDetails?sku=QUA-WTR1625L&viewState=DetailView&cartID=&g=|WTR1625L|new_window=true] RF Transceiver
