Traduciendo paso 11
Paso 11
The next logical step is to remove the battery from the iPhone 6 Plus.
The battery connector is covered by a metal bracket, which we dispose of using our metal tweezers.
Here's what we know about sticky iPhone battery pull tabs: pull it right, and it is super easy; pull it wrong, and it is the end of the world.
This adhesive is similar to a 3M Command adhesive, and when you pull the tab correctly it shears the entire strip off.
[* black] The next logical step is to remove the battery from the iPhone 6 Plus. | |
- | [* black] The battery connector is covered by a metal bracket, which we dispose of using our metal tweezers. |
+ | [* black] The battery connector is covered by a metal bracket, which we dispose of using our metal [product|IF145-020|tweezers]. |
[* icon_note] Near the bottom of the battery, we locate some sticky pull tabs. | |
[* black] Here's what we know about sticky iPhone battery pull tabs: pull it right, and it is super easy; pull it wrong, and it is the end of the world. | |
[* black] This adhesive is similar to a 3M Command adhesive, and when you pull the tab correctly it shears the entire strip off. |
