Saltar al contenido principal
LG G2 LCD and Digitizer Replacement
Inglés
Español
Paso 10
LG G2 LCD and Digitizer Replacement: paso 0, imagen 1 de 3 LG G2 LCD and Digitizer Replacement: paso 0, imagen 2 de 3 LG G2 LCD and Digitizer Replacement: paso 0, imagen 3 de 3
  • Take a thin prying tool and slide it between the glass and the plastic housing of the phone.
  • Go around the perimeter of the phone and lift the glass free. Do not slide your opening tool in too deep while doing this.
  • Don't slice any cables! There's one in the upper-right corner, plus a wide, flat one with two connectors on the bottom, towards the middle of the screen.
  • Carefully pry the ribbon glued down on the inside opposite the screen. Once that is free, slide it and the small connector through the case just to the side of it out to free up the screen to remove.
  • Be sure when replacing the screen to use a good bit of double-sided tape. I had problems with the bottom right corner coming up and had to disassemble and reapply tape.
Insertar traducción aquí
