Saltar al contenido principal
Reemplazo de tapa trasera del Nexus 5
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Nexus 5 Back Cover Replacement: paso 0, imagen 1 de 3 Nexus 5 Back Cover Replacement: paso 0, imagen 2 de 3 Nexus 5 Back Cover Replacement: paso 0, imagen 3 de 3
  • Use a plastic opening tool to free the clips on the top and each side of the back cover.
  • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
  • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
  • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
Usa una herramienta de apertura de plástico para liberar los clips en la parte superior de cada lado de la tapa trasera.
La parte inferior está sujeta con espuma adhesiva. Podrás finalmente liberar la tapa trasera utilizando una púa de apertura.
Es mejor evitar hacer palanca alrededor de la ranura de la tarjeta SIM., ya que el plástico aquí es muy delgado y puede romperse al hacer palanca.
[* black] Use a plastic opening tool to free the clips on the top and each side of the back cover.
-[* icon_note] The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick.
-[* icon_note] It's best to avoid prying around the SIM card slot, as the plastic here is very thin and likely to break from prying.
+[* icon_note] The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
+[* icon_caution] It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
+[* icon_reminder] When you ''replace'' the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
