Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 76 guías que incluyen este paso.
Traduciendo paso 12
Paso 12
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
