Saltar al contenido principal
Reemplazo de Cámara frontal y cable de sensor frontal de iPhone 5S
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 3
iPhone 5s Front Facing Camera and Sensor Cable  Replacement: paso 0, imagen 1 de 2 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: paso 0, imagen 2 de 2
  • In order to ensure a good fit and proper placement of components, make sure your new cable assembly matches the one that came out of your iPhone.
  • You may need to use a set of tweezers to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
Para asegurar un buen agarre y una colocación adecuada, asegúrate de que el nuevo conjunto de cable coincide con el que sale de tu iPhone.
Puedes necesitar un par de pinzas para doblar la porción del cable del micrófono para que la parte de oro está adentro del cable, y la de plata arriba.
[* icon_note] In order to ensure a good fit and proper placement of components, make sure your new cable assembly matches the one that came out of your iPhone.
-[* black] You may need to use a set of tweezers to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
+[* black] You may need to use a set of [product|IF145-020|tweezers] to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
