Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below.
- | [* black] Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below. |
+ | [* black] Using the edge of a set of [product|IF145-020|tweezers] or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below. |
[* icon_caution] ***Only pry directly under the earpiece speaker contacts***—there are sensors and microchips that can be damaged by prying elsewhere. |
