Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 32 guías que incluyen este paso.
Traduciendo paso 5
Paso 5
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
[* black] Pull the blue handle forwards to lock the arms. | |
[* black] Turn the handle clockwise 360 degrees or until the cups start to stretch. | |
[* icon_note] Make sure the suction cups [link|https://guide-images.cdn.ifixit.com/igi/BSluctHhVVqhGtfj.full|remain aligned with each other|new_window=true]. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms. | |
- | [* black] Insert an opening |
+ | [* black] Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap. |
[* icon_note] If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn. | |
[* icon_caution] ***Don't crank more than a quarter turn at a time and wait a few seconds between turns***. Let the Anti-Clamp and time do the work for you. | |
[* black] ***Skip the next two steps.*** |
