Saltar al contenido principal
Reemplazo del ensamblaje del panel frontal del iPhone 5s
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 32 guías que incluyen este paso.
Inglés
Español
Paso 10
iPhone 5s Front Panel Assembly Replacement: paso 0, imagen 1 de 2 iPhone 5s Front Panel Assembly Replacement: paso 0, imagen 2 de 2
  • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
  • Slide the top of the bracket over the Touch ID cable connector from left to right.
  • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
Durante el reensamblaje, necesitaras reinstalar el soporte del cable de Touch ID. La parte superior del soporte necesita ser deslizada entre la bateria y el conector de cable de Touch ID, en frente de la pestaña de metal, y la parte delantera debe de cerrar sobre el conector.
Desliza la parte superior del soporte sobre el conector de cable de Touch ID de la izquierda a la derecha.
[* icon_reminder] During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
[* icon_reminder] Slide the top of the bracket over the Touch ID cable connector from left to right.
+[* icon_note] Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
