Saltar al contenido principal
How to check the oil level in your Mercedes W123
Inglés
Español
Paso 3
How to check the oil level in your Mercedes W123: paso 0, imagen 1 de 1
  • The dip stick will come out with oil covering the tip. On a diesel engine it is normal for the oil to be dark black; the oil is designed to hold the diesel soot in suspension. If this were a gas engine it would definitely be time to change the oil just by the visual appearance of it! On a diesel you'll have to go more by age or mileage.
  • The oil level should fall somewhere between the notches on the tip of the stick. The notches mean:
  • Low - add oil
  • Full
  • If oil is at or below the Low notch add oil slowly, checking the level occasionally, until it reaches the Full notch.
  • Never overfill your engine with oil! Especially on a diesel. It can be pulled in to the cylinders and it could lead to a run-away engine.
Insertar traducción aquí
