Saltar al contenido principal
Reemplazo de cámara trasera del iPhone 5s
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
iPhone 5s Rear Facing Camera Replacement: paso 0, imagen 1 de 3 iPhone 5s Rear Facing Camera Replacement: paso 0, imagen 2 de 3 iPhone 5s Rear Facing Camera Replacement: paso 0, imagen 3 de 3
  • Using a pair of tweezers, flip the rubber camera cover out of its clip and toward the outside of the rear case.
  • Do not attempt to fully remove this cover. It is attached to the rear case and only needs to be flipped open, not removed.
Con unas pinzas, voltea la tapa de goma de la cámara y sácala de su clip hacia la parte externa de la caja trasera.
No intentes remover completamente esta tapa. Está sujeta a la caja trasera y necesita solo abrirse de un tirón no removerse.
-[* black] Using a pair of tweezers, flip the rubber camera cover out of its clip and toward the outside of the rear case.
+[* black] Using a pair of [product|IF145-020|tweezers], flip the rubber camera cover out of its clip and toward the outside of the rear case.
[* icon_caution] ***Do not*** attempt to fully remove this cover. It is attached to the rear case and only needs to be flipped open, not removed.
