Saltar al contenido principal
Reemplazo de cámara trasera del iPhone 5s
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
iPhone 5s Rear Facing Camera Replacement: paso 0, imagen 1 de 2 iPhone 5s Rear Facing Camera Replacement: paso 0, imagen 2 de 2
  • Using a pair of tweezers, flip the rubber camera cover out of its clip, and toward the outside of the rear case.
  • Do not attempt to fully remove this cover, it is attached to the rear case, and only needs to be flipped open, not removed.
Utilizando un par de pinzas, saca la tapa de goma de la cámara de su clip y apártala hacia la parte externa de la caja trasera.
No intentes de remover completamente la tapa. Está sujeta a la caja trasera y solo necesita abrirse no removerse.
-[* black] Using a pair of tweezers, flip the rubber camera cover out of its clip, and toward the outside of the rear case.
+[* black] Using a pair of [product|IF145-020|tweezers], flip the rubber camera cover out of its clip, and toward the outside of the rear case.
[* icon_caution] ***Do not*** attempt to fully remove this cover, it is attached to the rear case, and only needs to be flipped open, not removed.
