Saltar al contenido principal
Marshall MS-2 Micro Amp Circuit Board Disassembly
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 3
Paso 3
Marshall MS-2 Micro Amp Circuit Board Disassembly: paso 0, imagen 1 de 3 Marshall MS-2 Micro Amp Circuit Board Disassembly: paso 0, imagen 2 de 3 Marshall MS-2 Micro Amp Circuit Board Disassembly: paso 0, imagen 3 de 3
  • Now you must remove the LED from the circuit board.
  • To do this you will need to use a soldering iron to detach to two pins of the LED from the board. They are the two pins in the lowest leftmost corner of the board.
  • Be careful to not touch any of the wires with the soldering iron. It might be helpful to remove those with the iron first to get them out of the way.
  • If you haven't soldered before check out this guide.
  • Once detached, pull the board straight up to remove.
Insertar traducción aquí
