Saltar al contenido principal
iBook G4 14" 933 MHz-1.33 GHz Upper Case Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 20 guías que incluyen este paso.
Inglés
Español
Paso 5
iBook G4 14" 933 MHz-1.33 GHz Upper Case Replacement: paso 0, imagen 1 de 1
  • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
Insertar traducción aquí
