Saltar al contenido principal
Reemplazo de la placa madre y el disipador de calor
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 12
Xbox Series X Motherboard Removal (Motherboard): paso 0, imagen 1 de 2 Xbox Series X Motherboard Removal (Motherboard): paso 0, imagen 2 de 2
  • Roll the thermal putty into a ball.
  • Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
  • Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
  • When you reattach the heat sink, you'll compress the thermal putty and it'll spread the ball out.
Insertar traducción aquí
+[* black] Roll the thermal putty into a ball.
+[* black] Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
+[* black] Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
+[* icon_note] When you reattach the heat sink, you'll compress the thermal putty and it'll spread the ball out.
