Saltar al contenido principal
Xbox Series X Vervanging van het moederbord en de koellichaammodule
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 8
Xbox Series X Motherboard Removal (Motherboard), Thermal putty replacement: paso 0, imagen 1 de 2 Xbox Series X Motherboard Removal (Motherboard), Thermal putty replacement: paso 0, imagen 2 de 2
  • Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
  • If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
  • If you're only replacing the thermal paste, skip to this step.
Insertar traducción aquí
[title] Thermal putty replacement
[* yellow] Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
-[* black] If any pieces are damaged or dried out, remove and replace them:
- [* icon_note] Note the location, shape, and size of the originals pieces of thermal putty. When replacing them, the pieces of putty need to be the same.
- [* black] Use a spudger to ''gently'' scrape up larger pieces of putty, being very careful not to damage anything on the board.
- [* black] Use isopropyl alcohol and coffee filters or cotton swabs to clean up ''all'' the thermal putty residue.
- [* black] Apply new pieces of ''putty'' (***not*** thermal paste) that are the same size and shape as the originals.
+[* black] If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
+[* black] If you're only replacing the thermal paste, skip to this step.
