Saltar al contenido principal
Reemplazo de la cubierta inferior de la Mac mini (2024)
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Paso 6
Mac mini (2024) Bottom Cover Replacement, Disconnect the power button: paso 0, imagen 1 de 2 Mac mini (2024) Bottom Cover Replacement, Disconnect the power button: paso 0, imagen 2 de 2
  • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
  • To disconnect the cable and remove the bottom cover, follow the next two steps.
  • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
  • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
Sujeta el cable del botón de encendido cerca del cabezal y tira de él para desconectarlo.
[title] Disconnect the power button
+[* icon_caution] ***The power button cable is very fragile!*** You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
+[* icon_note] To disconnect the cable and remove the bottom cover, follow the next two steps.
+[* icon_note] If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
[* black] Grip the power button cable close to the head and pull it away from its socket to disconnect it.
