Saltar al contenido principal
Xbox Series X Optical Drive Replacement
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 7
Xbox Series X Optical Drive Replacement, Desolder the two wires: paso 0, imagen 1 de 2 Xbox Series X Optical Drive Replacement, Desolder the two wires: paso 0, imagen 2 de 2
  • Use a soldering iron to desolder the red wire in the corner of the optical drive board.
  • Then, desolder the adjacent black wire. Use a pair of blunt tweezers to hold and pull away the wires from the board.
  • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
  • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long periods of time.
  • When you install the original board into the replacement optical drive, solder the red wire to the solder pad labeled R. Solder the black wire to the solder pad labeled B.
Insertar traducción aquí
