Saltar al contenido principal
HP All-in-one PC Model 24 Motherboard Replacement
Inglés
Holandés
Paso 15
HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: paso 0, imagen 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: paso 0, imagen 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: paso 0, imagen 3 de 3
  • Locate the WiFi card
  • Unscrew the WiFi card: The WiFi card is secured with one screw. Use the precision screwdriver to remove the screw holding the WiFi card in place. Keep the screw in a safe location.
  • Remove the WiFi Card: Once the screw is removed, gently pull the WiFi card directly away from the PCIs slot. Be careful not to apply excessive force, as the card can be fragile.
  • WARNING: Do not apply excessive force to the card. The card should come out very easily.
Insertar traducción aquí
