Saltar al contenido principal
HP All-in-one PC Model 24 Motherboard Replacement
Inglés
Español
Paso 8
HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: paso 0, imagen 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: paso 0, imagen 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: paso 0, imagen 3 de 3
  • Locate the Storage Drive
  • Unscrew the Storage: Use a screwdriver to remove any screws securing the storage drive.
  • Very Small Screw: This screw requires the precision screwdriver.
  • Remove the Storage Drive: Once the screws are removed, remove the drive from the compartment. Do this by pulling directly away from the connector.
  • WARNING: Do not pull with excessive force. The drive should come out easily.
  • Note: Place the storage drive in a safe location to prevent any static discharge or physical damage.
Insertar traducción aquí
