Saltar al contenido principal
HP All-in-one PC Model 24 Motherboard Replacement
Inglés
Holandés
Paso 6
HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Screen: paso 0, imagen 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Screen: paso 0, imagen 2 de 2
  • Disconnect the Ribbon Cable: Gently lift the small locking mechanism or tab that secures the ribbon cable.
  • Note: This is often a ZIF (Zero Insertion Force) connector, which can be carefully pulled up to release the cable.
  • WARNING: Be very gentle when handling the ribbon cable, as it can be fragile and can tear if too much force is applied.
  • Carefully remove the Ribbon Cable: Once the tab is lifted, gently pull the ribbon cable out of its connector.
  • Note: Take care not to pull on the cable too harshly, as it may be connected to other parts. Also, make sure it is not bent or damaged during the process.
  • Note If your fingernails cannot reach the connector, see step 13 for an alternative method.
Insertar traducción aquí
