Saltar al contenido principal
HP All-in-one PC Model 24 Motherboard Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
HP All-in-one PC Model 24 Motherboard Replacement, Remove the Front Panel: paso 0, imagen 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Remove the Front Panel: paso 0, imagen 2 de 2
  • Pry Open the Front Panel: Using the prying tool, gently slide it between the front panel and the main body of the PC at the bottom of the computer. Work your way around the bottom edge, carefully detaching the clips holding the panel.
  • WARNING: Do not put the prying tool between the screen and the panel.
  • Remove the Front Panel: Lift the front panel away from the PC once all clips are detached. Set it aside in a safe place.
  • Power off the PC: Ensure that the PC is turned off and unplugged from the power source. Press the power button once to decharge the computer fully.
Insertar traducción aquí
