Saltar al contenido principal
Power Button Board Removal
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Power Button Board Removal: paso 0, imagen 1 de 3 Power Button Board Removal: paso 0, imagen 2 de 3 Power Button Board Removal: paso 0, imagen 3 de 3
  • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
  • Use your fingers to peel up the power button cable and fully separate it from the shell.
  • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
Insertar traducción aquí
