Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Traduciendo paso 3
Paso 3
Remove the fan
Slide the fan out of its slot to remove it.
Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
Note that the fan can only be installed one way—make sure Master Chief is facing you.
[title] Remove the fan | |
[* black] Slide the fan out of its slot to remove it. | |
- | [* icon_reminder] During reinstallation, note that the fan can only be installed one way—make sure [link|https://d3nevzfk7ii3be.cloudfront.net/igi/hZQNu3JSXQ4MaVXE.full|Master Chief|new_window=true] is facing you. |
- | [* icon_note] If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide. |
+ | [* icon_reminder] During reassembly: |
+ | [* black] Before installing the fan, make sure it's clean! Use a [product|IF145-064-2|dust blower|new_window=true] or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth. |
+ | [* icon_note] Use a finger to keep the fan blades steady—it makes them easier to clean. |
+ | [* black] Note that the fan can only be installed one way—make sure [link|https://d3nevzfk7ii3be.cloudfront.net/igi/hZQNu3JSXQ4MaVXE.full|Master Chief|new_window=true] is facing you. |
