Saltar al contenido principal
Sustitución del ventilador de una Xbox Series X
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Fan Removal, Remove the fan: paso 0, imagen 1 de 3 Fan Removal, Remove the fan: paso 0, imagen 2 de 3 Fan Removal, Remove the fan: paso 0, imagen 3 de 3
Remove the fan
  • Slide the fan out of its slot to remove it.
  • During reassembly:
  • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
  • Use a finger to keep the fan blades steady—it makes them easier to clean.
  • Note that the fan can only be installed one way—make sure Master Chief is facing you.
Desliza el ventilador fuera de su ranura.
Durante la reinstalación, ten en cuenta que el ventilador solo puede instalarse de una forma -asegúrate que Master Chief esté de frente a ti.
Si estás reemplazando el ventilador, es posible que un ventilador nuevo no incluya el soporte de instalación de plástico, que se fija al ventilador con cuatro tornillos Torx T10. Esto no se muestra en esta guía.
[title] Remove the fan
[* black] Slide the fan out of its slot to remove it.
-[* icon_reminder] During reinstallation, note that the fan can only be installed one way—make sure [link|https://d3nevzfk7ii3be.cloudfront.net/igi/hZQNu3JSXQ4MaVXE.full|Master Chief|new_window=true] is facing you.
- [* icon_note] If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
+[* icon_reminder] During reassembly:
+ [* black] Before installing the fan, make sure it's clean! Use a [product|IF145-064-2|dust blower|new_window=true] or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
+ [* icon_note] Use a finger to keep the fan blades steady—it makes them easier to clean.
+ [* black] Note that the fan can only be installed one way—make sure [link|https://d3nevzfk7ii3be.cloudfront.net/igi/hZQNu3JSXQ4MaVXE.full|Master Chief|new_window=true] is facing you.
