Saltar al contenido principal
Dell G15 5511: How to Fix the Hinge Cracking Problem
Inglés
Español
Paso 6
Dell G15 5511: How to Fix the Hinge Cracking Problem: paso 0, imagen 1 de 2 Dell G15 5511: How to Fix the Hinge Cracking Problem: paso 0, imagen 2 de 2
  • Flip the laptop over while securing the bottom cover and set it down with the top cover facing up and the hinge screws facing you. You now have access to the eight M2.5x4(4mm) hinge screws.
  • Use a Phillips #0 screwdriver to tighten any loose screws, but don't overdo it.
  • There are potential problems caused by screws that are overtightened too.
  • Carefully open and close the top cover of the laptop to test the hinges and adjust the screws accordingly, based on your personal preference for how tight you want it to be.
  • Optionally, you can leave the case off as shown in this guide, or if you're satisfied with the grip, reattach the cover over the hinges before proceeding to the next step.
Insertar traducción aquí
