Saltar al contenido principal
Dell G15 5511: How to Fix the Hinge Cracking Problem
Inglés
Español
Paso 2
Dell G15 5511: How to Fix the Hinge Cracking Problem: paso 0, imagen 1 de 3 Dell G15 5511: How to Fix the Hinge Cracking Problem: paso 0, imagen 2 de 3 Dell G15 5511: How to Fix the Hinge Cracking Problem: paso 0, imagen 3 de 3
  • Rotate the laptop so the hinge edge is facing you.
  • Use a Phillips #0 screwdriver to remove the two 5 mm screws.
  • Use something like the magnetic FixMat and a dry erase marker to note where the screws are located on your device and keep them organized for reassembly.
Insertar traducción aquí
