Saltar al contenido principal
iMac Intel 21.5" EMC 2638 Teardown
Inglés
Español
Traduciendo paso 8
Paso 8
iMac Intel 21.5" EMC 2638 Teardown: paso 0, imagen 1 de 2 iMac Intel 21.5" EMC 2638 Teardown: paso 0, imagen 2 de 2
  • iMac 21.5" EMC 2638 Repairability Score: 2 out of 10 (10 is easiest to repair)
  • You can still replace the RAM and hard drive inside this machine...with a lot of adhesive cutting.
  • Budget-minded folks now can add a second hard drive to the base iMac because the Fusion Drive connector is no longer missing from the logic board.
  • The CPU is soldered to the logic board, and cannot be replaced or upgraded.
  • The glass and LCD are fused together, and there are no more magnets holding the glass in place.
  • Most replaceable components (like the RAM) are buried behind the logic board, meaning you'll have to take apart most of the iMac just to gain access to them.
  • You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
Insertar traducción aquí
