Saltar al contenido principal
Kit soldadura de bricolaje para linternas LED básicas
Inglés
Español
Paso 9
Basic LED Flashlight DIY Soldering Kit Assembly, Solder the resistor: paso 0, imagen 1 de 3 Basic LED Flashlight DIY Soldering Kit Assembly, Solder the resistor: paso 0, imagen 2 de 3 Basic LED Flashlight DIY Soldering Kit Assembly, Solder the resistor: paso 0, imagen 3 de 3
Solder the resistor
  • In this step, you're going to heat the solder pad and the resistor's lead so that they'll readily melt the solder wire.
  • Press the tip against the circuit board's solder pad and the resistor's lead for a few seconds to heat them both. Angle the tip so it has maximum contact with the pad and lead.
  • If you heat the circuit board continuously for more than 10 seconds, the excessive heat may damage the solder pad or resistor.
  • Feed the solder wire into the heated area until there's a concave pool ("mini volcano") of solder surrounding the lead.
  • Don't feed the solder directly onto the tip as it won't flow properly into the pad and lead, causing a weak connection.
  • The volcano should form within a few seconds. If the solder doesn't adhere to the pad, apply flux to the pad or increase the temperature.
  • Remove the solder wire first, then remove the soldering iron from the pad.
  • Repeat this process for the second resistor lead.
En este paso, vas a calentar la almohadilla de soldadura y el cable de la resistencia para que fundan fácilmente el hilo de soldadura.
Presiona la punta contra la almohadilla de soldadura de la placa de circuito y el cable de la resistencia durante unos segundos para calentar ambos. Coloca la punta en ángulo para que tenga el máximo contacto con la almohadilla y el cable.
Si calientas la placa de circuito de forma continuada durante más de 10 segundos, el calor excesivo puede dañar la almohadilla de soldadura o la resistencia.
Introduce el cable de soldadura en la zona calentada hasta que se forme un charco cóncavo («mini volcán») de soldadura alrededor del cable.
No introduzcas la soldadura directamente en la punta, ya que no fluirá correctamente hacia la almohadilla y el cable, provocando una conexión débil.
El volcán debería formarse en unos segundos. Si la soldadura no se adhiere a la almohadilla, aplica flujo a la almohadilla o aumenta la temperatura.
Retira primero el cable de soldadura y, a continuación, el soldador de la almohadilla.
Repite este proceso con el segundo cable de la resistor.
