Saltar al contenido principal
Weber Charcoal Kettle Grill Cleaning System Replacement
Inglés
Español
Paso 2
Weber Charcoal Kettle Grill Cleaning System Replacement: paso 0, imagen 1 de 3 Weber Charcoal Kettle Grill Cleaning System Replacement: paso 0, imagen 2 de 3 Weber Charcoal Kettle Grill Cleaning System Replacement: paso 0, imagen 3 de 3
  • Lay the grill upside down on a flat surface.
  • Using a towel to lay your grill on will help to avoid damage to the grill or the flat surface.
  • Use a pair of pliers to remove the screw holding the old cleaning system in place. Once the screw is removed the assembly should come apart easily.
  • Turn the grill on its side.
Insertar traducción aquí
