Saltar al contenido principal
DualSense Edge Vibration Motors Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
DualSense Edge Vibration Motors Replacement, Remove the vibration motor: paso 0, imagen 1 de 3 DualSense Edge Vibration Motors Replacement, Remove the vibration motor: paso 0, imagen 2 de 3 DualSense Edge Vibration Motors Replacement, Remove the vibration motor: paso 0, imagen 3 de 3
  • This guide is for the right vibration motor, which is on your left. The process for the left motor is identical.
  • Use a spudger to push on the vibration motor through the hole in the midframe at the top of the vibration motor housing.
  • Once the vibration motor has released from the adhesive in the housing, grab and remove it.
  • During reassembly:
  • Use high-concentration (>90%) isopropyl alcohol and a coffee filter or lint-free cloth to remove the adhesive from the vibration motor housing.
  • Apply double-sided tape, like Tesa tape, to the housing in the same place as the old adhesive.
  • If your new vibration motor does not have a foam pad, transfer the pad from the old motor to the new one.
Insertar traducción aquí
