Saltar al contenido principal
DualSense Edge Speaker Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
DualSense Edge Speaker Replacement, Remove the speaker: paso 0, imagen 1 de 2 DualSense Edge Speaker Replacement, Remove the speaker: paso 0, imagen 2 de 2
Remove the speaker
  • Use tweezers or your fingers to lift and remove the speaker from the center of the midframe.
  • During reassembly:
  • Check that your new speaker has a piece of foam on the back. If it doesn't, transfer the foam from the old speaker to the new one.
  • Install the speaker so the raised portion of the contact springs are to the right. If you are unsure of the correct orientation, check the motherboard and make sure the springs make contact with the posts on the motherboard.
Insertar traducción aquí
