Saltar al contenido principal
DualSense Edge Trigger Assembly Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
DualSense Edge Trigger Assembly Replacement, Move the vibration motor cable: paso 0, imagen 1 de 3 DualSense Edge Trigger Assembly Replacement, Move the vibration motor cable: paso 0, imagen 2 de 3 DualSense Edge Trigger Assembly Replacement, Move the vibration motor cable: paso 0, imagen 3 de 3
  • This procedure is written using the R2 trigger assembly, which is on your left. The procedure to remove the L2 assembly is identical.
  • Use a pair of tweezers to disconnect the vibration motor cable by lifting the JST connector out of its socket.
  • This cable is connected to the back button board, between the RB or LB button and the vibration motor.
  • Continue lifting until the vibration motor cable is free of the clip on the trigger assembly.
Insertar traducción aquí
