Saltar al contenido principal
DualSense Edge Rear Case Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
DualSense Edge Rear Case Replacement, Remove the L1 and R1 buttons: paso 0, imagen 1 de 3 DualSense Edge Rear Case Replacement, Remove the L1 and R1 buttons: paso 0, imagen 2 de 3 DualSense Edge Rear Case Replacement, Remove the L1 and R1 buttons: paso 0, imagen 3 de 3
  • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
  • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
  • Use the spudger to pry out the L1 button.
  • The buttons tend to shoot out in this step. You can place your thumb over the button to prevent this.
  • Repeat this process to remove the R1 button.
Insertar traducción aquí
