Saltar al contenido principal
DualSense Edge Rear Trim Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 15 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
DualSense Edge Rear Trim Replacement, Insert an opening pick: paso 0, imagen 1 de 3 DualSense Edge Rear Trim Replacement, Insert an opening pick: paso 0, imagen 2 de 3 DualSense Edge Rear Trim Replacement, Insert an opening pick: paso 0, imagen 3 de 3
  • The rear trim is held in place by fragile plastic clips. Work slowly and gently to avoid breaking the clips.
  • If you installed the back button paddles included with your controller, remove them before beginning this process.
  • Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
  • Slide the opening pick towards the bottom of the grip to release the clips.
Insertar traducción aquí
