Saltar al contenido principal
DualSense Edge Front Trim Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 17 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
DualSense Edge Front Trim Replacement, Remove the front trim: paso 0, imagen 1 de 3 DualSense Edge Front Trim Replacement, Remove the front trim: paso 0, imagen 2 de 3 DualSense Edge Front Trim Replacement, Remove the front trim: paso 0, imagen 3 de 3
  • Place the controller on a work surface with the joysticks facing down.
  • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
  • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
  • Lift the controller up, leaving the front trim on the table.
  • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
Insertar traducción aquí
