Saltar al contenido principal
Reemplazo de cámaras traseras del Google Pixel 9 Pro XL
Inglés
Español
Traduciendo paso 1
Paso 1
Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: paso 0, imagen 1 de 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: paso 0, imagen 2 de 3 Google Pixel 9 Pro XL Rear Cameras Replacement, Disconnect the rear cameras: paso 0, imagen 3 de 3
  • Be very careful not to damage any of the small, surface‑mounted components when disconnecting the cameras in the next two steps.
  • Hold the logic board above your work surface while disconnecting the rear cameras—don't press the board against your work surface, or you may damage fragile components.
  • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector on the top of the logic board, near the left edge.
Ten mucho cuidado de no dañar ninguno de los componentes pequeños montados en la superficie durante los dos pasos siguientes.
Usa la punta de un spudger para levantar y desconectar el conector de presión del sensor de enfoque automático en la parte superior de la placa lógica, cerca del borde izquierdo.
[title] Disconnect the rear cameras
-[* icon_caution] Be very careful not to damage any of the small, surface‑mounted components during the next two steps.
+[* icon_caution] Be very careful not to damage any of the small, surface‑mounted components when disconnecting the cameras in the next two steps.
+[* black] Hold the logic board above your work surface while disconnecting the rear cameras—don't press the board against your work surface, or you may damage fragile components.
[* black] Use the point of a spudger to pry up and disconnect the autofocus sensor press connector on the top of the logic board, near the left edge.
