Saltar al contenido principal
Desconexión de la batería
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Kobo Clara Colour Battery Disconnection, Disconnect the battery: paso 0, imagen 1 de 2 Kobo Clara Colour Battery Disconnection, Disconnect the battery: paso 0, imagen 2 de 2
  • Insert the point of a spudger under the edge of the battery connector head opposite of the cable.
  • There's a surface-mounted component close to the connector. Be careful not to touch it with your spudger!
  • Lift up the connector with the spudger to separate the rest of the coating and disconnect the battery.
  • During reassembly:
  • Inspect the connector head and its socket for any remaining coating that could prevent a good connection.
  • Peel off the coating, heating the area when the coating becomes too brittle.
  • It doesn't have to look pretty! You just need to remove enough coating so the connector head sits properly in its socket.
Introduce la punta de un spudger bajo el borde del cabezal del conector de batería opuesto al cable.
Hay un componente montado en https://guide-images.cdn.ifixit.com/igi/.... ¡Ten cuidado de no tocarlo con el spudger!
Insertar traducción aquí
