Use a spudger to remove the CMOS battery from the board.
It is attached with a small amount of adhesive so you may need to pry it off, but be careful not to puncture or bend the battery.
Use a spudger to disconnect the CMOS battery connector cable from the motherboard.
To disconnect, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
Don't push on the cables themselves, or you may damage the connector.
Atajos de Teclado para Edicion de Pasos de Guia:
Ctrl + Shift + N
Insertar una nueva línea debajo
Ctrl + Shift + P
Insertar una nueva línea arriba
Ctrl + ]
Eliminar línea actual
Ctrl + [
Línea actual sin sangría
Ctrl + D
Shift + ;
Ve al siguiente paso.
Shift + H
Ve al paso anterior.
Ver todos los atajos
