Saltar al contenido principal
Dell XPS 15 9575 I/O Board Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Dell XPS 15 9575 I/O Board Replacement: paso 0, imagen 1 de 2 Dell XPS 15 9575 I/O Board Replacement: paso 0, imagen 2 de 2
  • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector.
  • Use tweezers or your fingers to gently pull the orange cable out of its socket on the I/O board.
  • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
  • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
Insertar traducción aquí
