Saltar al contenido principal
Meta Quest 2 Controller Side Shell Prereq
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 5
Meta Quest 2 Controller Side Shell Prereq: paso 0, imagen 1 de 2 Meta Quest 2 Controller Side Shell Prereq: paso 0, imagen 2 de 2
  • Part of the side shell is looped around a screw post. In this step, you’ll spread the screw post apart enough to slip the shell out.
  • Insert the flat end of a spudger into the gap between the controller ring and the front shell.
  • The front shell is the plastic frame part below the front trigger.
  • Twist the spudger to widen the gap between the front shell and the controller.
  • Position the spudger so that it can stay in place without you holding the tool.
Insertar traducción aquí
