Saltar al contenido principal
Meta Quest 2 Controller Faceplate prereq
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Holandés
Paso 2
Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: paso 0, imagen 1 de 3 Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: paso 0, imagen 2 de 3 Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: paso 0, imagen 3 de 3
  • The controller faceplate is secured with adhesive and three friction pegs.
  • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
  • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
  • Slide the opening tool to the base of the ring shell to loosen the adhesive.
Insertar traducción aquí
