Saltar al contenido principal
LG Refrigerator Water Dispensing Switch Testing and Replacement
Inglés
Español
Traduciendo paso 5
Paso 5
LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: paso 0, imagen 1 de 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: paso 0, imagen 2 de 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: paso 0, imagen 3 de 3
  • If you have a multimeter, you can test to see if your water dispensing switch is good or not. Set your multimeter to the continuity function, with beeper.
  • Touch one probe to each of the switch terminals at the same time.
  • When you operate the small lever on the switch the meter should sound.
  • When you release the small lever on the switch the meter should not sound.
  • If the switch does not operate as described above, replace it.
Insertar traducción aquí
