Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Traduciendo paso 3
Paso 3
Secure the Anti-Clamp
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
Slide the arms over the left edge of your phone, so you have access to the bottom edge.
Position the suction cups as close to the center of the bottom edge as possible.
Squeeze the cups together to create suction.
[title] Secure the Anti-Clamp | |
- | [* icon_note] The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. ***If you aren't using the Anti-Clamp, skip down three steps for an alternate method.*** |
+ | [* icon_note] The next three steps demonstrate the [product|IF145-513|Anti-Clamp], a tool we designed to make the opening procedure easier. ***If you aren't using the Anti-Clamp, skip down three steps for an alternate method.*** |
[* icon_note] For complete instructions on how to use the Anti-Clamp, [guide|152309|check out this guide|new_window=true]. | |
[* black] Pull the blue handle backwards to unlock the Anti-Clamp's arms. | |
[* black] Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off. | |
[* black] Slide the arms over the left edge of your phone, so you have access to the bottom edge. | |
[* black] Position the suction cups as close to the center of the bottom edge as possible. | |
[* black] Squeeze the cups together to create suction. |
