Saltar al contenido principal
Google Pixel 8 Pro 5G mmWave Antenna Replacement
Inglés
Holandés
Paso 5
Google Pixel 8 Pro 5G mmWave Antenna Replacement, Remove the thermal pad: paso 0, imagen 1 de 2 Google Pixel 8 Pro 5G mmWave Antenna Replacement, Remove the thermal pad: paso 0, imagen 2 de 2
  • Use a spudger to gently scrape up and remove the 5G mmWave antenna thermal pad, being careful not to damage it.
  • Set the thermal pad aside for reassembly.
  • During reassembly, transfer the old thermal pad to your new 5G mmWave antenna. Use the flat end of a spudger to help push it into place. If the thermal pad is damaged, you'll need to replace it with a new one.
Insertar traducción aquí
