Saltar al contenido principal
Fast Fix Fluval Spec V Impeller Replacement
Inglés
Español
Paso 4
Fast Fix Fluval Spec V Impeller Replacement: paso 0, imagen 1 de 2 Fast Fix Fluval Spec V Impeller Replacement: paso 0, imagen 2 de 2
  • Caution: To protect Neocaridina shrimps, nano fish, and other small aquatic creatures in your aquarium, an extra precautionary step is necessary due to the potential danger posed by the outlet leading into the filtration compartment, which could cause them to get stuck behind the divider.
  • Cover Outlet (Optional): Carefully insert a suitable filter medium into the outlet.
  • This could be a piece of sponge, mesh, or any other aquarium-safe material that allows water flow while preventing the shrimps or fish from entering the filtration compartment. Be sure to securely place the filter medium so that it doesn't shift or come loose, potentially leaving the outlet unprotected.
Insertar traducción aquí
